Hello,
I've installed the Trial Version on my notebook and use it with an Audio 8.
After start the CPU usage is regularly abou 10/15 % and pulsing to 50/60 % about every 10 seconds.
I ran DPC Latency check during this, no problems. (max was 518).
I ran the windows resource monitor and saw the same peaks.
When I close VDJ the peaks in resource monitor are gone,
so it seems to me, thats VDJ is causing theses CPU peaks.
My Notebook is a HP Tx2650eg, 4GB RAM ...
wifi is turned off
Windows 7 RC
wifi is turned off
Windows 7 RC
Posted Tue 30 Jun 09 @ 7:43 pm
Post up any ASIO settings from your soundcard control panel, as well as the sound setup and performances tab in VDJ's config. There are some users here who use the NI Audio cards without issue, so I suspect it is configuration or system related.
Posted Tue 30 Jun 09 @ 8:37 pm
OK, I have retranslated the names from german, so maybe they are not completly correct
ASIO Settings
medium latency (USB Buffersize 2ms, , Audio 8ms)
SR 441000 Hz
Ultra Latency ASIO is checked
Video is deactivated
fast screen resize is activated
internet is anything off
Performance ist on the 2nd preset from left.
Soundcard
Delay: Auto
Safemode & Overclock are checked.
Scratch:
optimized for quality
enhanced algorithm
filter size 11, smooth not checked
48<>44
Lowpass
Mastertempo: Fast
ASIO Settings
SR 441000 Hz
Soundcard
Delay: Auto
Scratch:
enhanced algorithm
48<>44
Lowpass
Mastertempo: Fast
Posted Tue 30 Jun 09 @ 10:19 pm
What skin are you running and whats your screen resolution? If they aren't the same, are you running the skin maximized or resized?
Posted Wed 01 Jul 09 @ 5:47 am
