Hi,
Would it be posiible to blink the LEDS on button 1 to 6 on the Hercules RMX?
I have assigned these buttons to flanger, echo and other effects (more then the skin shows).
I disabled the in VDJ options to clear effects on load, because then my fader curves will be cleared also.
If the leds will blink I can see which effects are still switched on or active when I load a new song to the desk.
And can decide to leave the effect on or switch it off. Now I am in the blind.
freek
freek
Posted Tue 30 Jun 09 @ 2:43 am
you cannot add any leds to the rmx unfortunately, we got what we got and like you am not very happy with hercules, if i had known that not all buttons did not not have functioning leds i don't think i would have purchased it, but am happy with the unit overall.
anyway if you use touchdans rmx skin it will show on screen the buttons that have been activated.
Posted Tue 30 Jun 09 @ 5:13 am
The 6x6 config buttons do not have backlighting (no LED's) so you won't be able to get them to blink.
There is only 16 buttons that do have backlighting. These are the ones that blink when the RMX is powered up.
Posted Tue 30 Jun 09 @ 6:44 am
Thanks.
Then a good SKIN would help me where the buttons are represented,
VDJ Radio fan was refering to touchdans rmx skin, but I can't find it.
freek
freek
Posted Tue 30 Jun 09 @ 6:47 am
you can call me tayla, everybody else does, lol. just replied to your pm.
Posted Tue 30 Jun 09 @ 6:56 am
