Hi Can someone please explain what i have to do to get this to work.
1. I highlight the netsearch in the left hand section
2. I type along the search bar Track or Artist or Both hit enter i get a quick flash on Netsearch Searching? and nothing happens?
3. I am signed in on the internet tab it says Full Membership are there any other settings that have to be made i have tried a number of songs to no avail.
4. Is there something in the firewall setting that has to be changed as i am on Medium setting now and i am not getting any warnings.
I have posted for support and the reply was less than helpful (mine's okay try another record).
Any ideas please.
Any ideas please.
Posted Mon 29 Jun 09 @ 9:34 am
are your settings correct in config > internet and have you logged in...
Posted Mon 29 Jun 09 @ 11:41 am
Hi yes it says connected full membership
Posted Mon 29 Jun 09 @ 1:31 pm
Do you have show music, videos, karaoke checked where you turn the album covers on and off in the browswer?
Posted Wed 01 Jul 09 @ 1:00 am
Hi thanks for reply i will check when i get in from work tonight
Posted Wed 01 Jul 09 @ 10:25 am
There's also a check for using netsearch only when no local resutls are found .
Posted Wed 01 Jul 09 @ 11:06 am
Hi thanks a lot have just ticked what you said and bingo, a whole new world has opened up.
thanks again :-)
thanks again :-)
Posted Wed 01 Jul 09 @ 1:12 pm
