I'm intrested in buillding my own bass bin but all of the ones on the market I feel are either too big or too heavy. So does anyone know where I can go to get plans on bass bins ?
Posted Sun 21 Jun 09 @ 10:31 am
Posted Sun 21 Jun 09 @ 10:44 am
That is great thanks anyone else have any sugestions.
Posted Sun 21 Jun 09 @ 10:04 pm
You can also build your own using Bass reflex cabinets that are pre-made for Car Audio subs
Buy a pre-made bass reflex cabinet (most common made speaker design) and place your chosen pro audio speaker (driver) in the case.
You can also buy pre-made passive crossovers and jackplates and in a couple of hours you can make a subwoofer.
****warning****
if you don't know what you're doing....FIND OUT!!!
****warning****
Posted Mon 22 Jun 09 @ 11:49 pm
