I used to be able to hit my ALT button for deck 1 or my Right ALT button for Deck 2 to get the LOOP OUT Effect engaged
This is what I used in the last version
deck 1 effect "LoopOut v2.01" active
deck 2 effect "LoopOut v2.01" active
I can't seem to figure out what the correct way to word this in the new version
any ideas??
any ideas??
Posted Sat 20 Jun 09 @ 12:28 pm
That is the correct syntax and works fine here ... deck 1 effect "LoopOut v2.01" active
Just make sure after you push the 'Alt' buttons that the Auto-Learn turns off ... otherwise you will end up changing the key to something else ...
'Alt' keys are no long wise keys to use as with the skin engine change. The 'Alt' keys typically are used to open a window's control box for Move, Minimize, Maximize, and Close.
Posted Sat 20 Jun 09 @ 3:53 pm
