hi guys i just got a hercules MP3 or mk1 whatever you like to call it. now i put the disc into my computer and it said that my operating system wasnt any good.
i run Vista premium and cant seem to get the Herc installed.
ive tried several driver sets and still cant get it to work.
has anyone experienced the same problem and got it to work? or does anyone know how to fix my problem.
Posted Wed 17 Jun 09 @ 11:22 am
Contact Hercules support - ts.hercules.com ... that will most likely be your quickest answer...
Posted Wed 17 Jun 09 @ 11:47 am
its ok ive sussed it!
turns out that my real time protection from Spyware Terminator was causing the installation of the 2009 vista drivers to fail.
i disabled my realtime protection and it worked. so now im playing happy with my new toy. not too fussed on the jogwheel action though its not very smooth. and its a bit too sensitive for my heavy handedness. other than that though all fine and dandy now.
Posted Wed 17 Jun 09 @ 12:07 pm
i have th mixer but no cd, can i download the software or can i get a new cd from somewhere?? cheers
Posted Tue 25 Jan 11 @ 12:42 pm
