I just purchased a Numark Omni Control as a backup and works great with VDJ 6.0.1 but how do I pitch bend? The + and - wher it says pitch bend do something with the loop and the jog wheel just does scratch mode. How do I get the jog wheel to pitch bend, because as of now it is way to sensitive and I dont want to bump it while playing.
Posted Tue 16 Jun 09 @ 12:55 pm
Anyone?
Posted Tue 16 Jun 09 @ 6:02 pm
maybe you have to custom map it....?
Posted Tue 16 Jun 09 @ 10:18 pm
it is natively controlled. I am not a computer geek that knows how to do this. works great but I do not have pitch control. I know people own this, where the hell are you?
Posted Wed 17 Jun 09 @ 4:15 am
Have you tried pressing the page button to see if it disables scratch mode for the jog wheels.
Posted Wed 17 Jun 09 @ 5:01 am
The jogs are pre-mapped as jog (pitch bend) wheels not scratch wheels.
Under the options tab make sure that jogwheel scratch is disabled - and then adjust the jogwheel sensitivity to your liking.
Posted Wed 17 Jun 09 @ 8:08 am
I will try that, thanks!!!
Posted Wed 17 Jun 09 @ 12:58 pm
