Topic: script help for jog pfl
guys anyone came up with script to use jog wheel as scratch when scratch selected on rmx and scroll songs when down pressed..tried but think im missing something thanks.also is there a way to map the seek buttons to samples
Posted Tue 16 Jun 09 @ 7:34 am
You already got the script for using the jog wheels for browsing songs with the up/down buttons (at least once!!).
The script previously provided (https://virtualdj.com/forums/110713/General_Discussion/jog_keeps_crashing.html) works for me, unless I'm misunderstanding what you're trying to achieve.
What exactly have you in the mapper for your up/down buttons? Reproduce your script here exactly as you have it entered, or better still, capture a screen shot of the mapper settings...
ok how do i do the screen sht part.and basicall did what you said last time and didnt work maybe i had something wrong.just got new rmx drivers and trying it again have hardset my 6 buttons gran this is what i want to do
scroll through song using job on non playing deck while i have down button pressed and scratch when i select scratch button on rmx
also can you set a sample to the seek buttons
Open up the mapper and click on the entry for the UP key. This will ensure the full action assigned to that key will display on the right hand side of your screen. Then press the Alt + PrtScr (Print Screen) keys. This will capture an image of the currently active window (i.e. the mapper window) and place it into your PC's copy/paste buffer.
Open up an image manipulation program (like MS Paint) and Paste the saved image and save this file. Post the saved file here.
Best to use some image hosting website, like ImageShack and then post the link to your image here by using the following format:
[ img ] put_your_image_url_here [ /img ]
(Note: don't use spaces before or after the square brackets "[" and "]" - they're included above so you can see the tags to use)
Once we can see what's in the mapper for your UP/DOWN keys we can take it from there...
ok djmga got jog working but only on left deck with your script mate what do i add for right jog also.
Glad you're getting there...
When you hit Cue Select on the other deck, the jog+up/down browsing functionality switches to that side. Remember thought, that the other deck's jog wheel is then only in scratch mode.
lol.ok what should my pfl action say as cue select not lighting or working.ok got it it is select.
now next question can i map samples to track- and +
and foripod use do i leave source as timecode bypass mate
ok must be learning got my sampl ie working on track-and+ and to stop
How'd yall get that scroll to work?
