Hi everybody, i'm new on the forum.
I can't make my hercules console work on virtual dj pro, it only works on the virtual dj version designed for the console.
any suggestion? i have even the skin of the console and on the external hardware it is activated!
Posted Sun 14 Jun 09 @ 2:47 pm
The DJ Control MP3 should work equally as well with VDJ Pro as it does with the included version. However, be sure to install the latest driver for your DJ Control :
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=179&cid=1
Posted Mon 15 Jun 09 @ 8:39 am
under sound setup make sure hercules console it selected and under remote control make sure u select and activate dj console upper left might want to stay away from vdj 6.0
Posted Tue 16 Jun 09 @ 12:38 am
