Hi,
I have a limited version of virtual dj, and from vdj 5.1 I have problems with the monitor (CUE/MIX). I was waiting for the new release of VDJ (v. 6) but it seems to include the same problem, at least in the trial version.
I have download and installed the last version of Console RMX drivers: 2009_HDJS_2.
I am running a PC with Windows XP SP3 installed.
My config is: Input: None / Output: Headphones / Card: dj console rmx / master: Channel 1&2 Headphones: 3&4
I have read and tested another configs like using asio as a card and I obtained the same problem.
My problem consints of:
When I have two songs playing:
a) I can hear only the song that is "cue selected" in cue and in mix position of the monitor when the crossfader selects "cue selected" song deck, but I can't hear the other song.
b) I can hear both songs at the same time in mix position of monitor and the "cue selected" song in cue position when the crossfader is in the middle.
c) I can hear in cue the song that is "cue selected" and in mix the song that is not "cue selected" when the crossfader select the deck of the song non "cue selected"
In the previous version I could hear the songs in a correct way... when the song is cue selected, it can be heard alone at cue position, and with the other song in mix position of the monitor.
I hope someone can help me in order to solve this problem :)
Thanks in advance
Thanks in advance
Posted Sun 14 Jun 09 @ 10:37 am
