When using the Xp10 map, scratch wheel not setup correctly.
Try this...
Play a song... touch the wheel and draw it back quickly. They hold should engage and the song should reverse. Not! For some reason the bend is engaging and bypassing the wheel touch message. The only way to get "somewhat proper" scratch is to nudge the wheel forward a little first then scratch. But if you do scratching tricks with a wheel touch release it completely messes up because it's not reversing properly. Not good at all guys! Btw... had been able to get it working fine on VDJ5.
Also, when is VDJ going to implement and slight lag into the touch wheel like Traktor? It needs a micro/subtle startup and slow down when touching the wheel. When you quickly tap the wheel it should not be a absolute start / stop. Doesn't sound natural at all. Made this request a long time ago btw.
Having a bi!<h trying to get it to work.
-dJ dAb
Try this...
-dJ dAb
Posted Sat 13 Jun 09 @ 10:55 pm
