Hello,
I'm using Traktor for the moment, and made a test of Virtual DJ.
One thing I need very often is to switch from TimeCode to internal Play on the Fly.
I only found the possibility to switch in the settings dialog.
Am I missing something or ist there no other possibility ...
I need to switch a single deck during a trlack is playing.
In Traktor it is also possible to switch back to relative mode later and turn the motor off for letting the track slow down ...
Posted Sat 13 Jun 09 @ 10:24 am
Yes you missing something, In the default skin of v6 there is (mixer, video, scratch) radio tabs. click on scratch then tc a /b off... in the lower versions you have to hit correct radio button depending the version.
Posted Sat 13 Jun 09 @ 10:55 am
