Is there any way to have the browser initially load in bpm order when vdj is started?
Posted Fri 12 Jun 09 @ 2:48 am
yes there is.. .ensure that in your browser section BPM is the first one you see
so you may have..... BPM..... TITLE......Artist... KEY
this should ensure that songs are listed by bpm first....
right click any heading on the browser panel
click order
select bpm
using the up arrow at the top of the dialog box move bpm until it is at the top
click ok
that should about do it.. .
so any folder you go into at all you should see this arrangement by bpm
Posted Fri 12 Jun 09 @ 5:34 am
That puts the BPM column at the beginning but they still dont sort into bpm order without having to get the mouse and click the bpm column. My goal is to not have to use mouse at all.
Posted Fri 12 Jun 09 @ 5:55 am
download the Registry Tool . run the tool .set sortordedefault & Sortorderforce = 6
Posted Fri 12 Jun 09 @ 6:21 am
Excellent - thanks. Some of the other settings are interesting. Is there some docs for the tool somewhere with what the settings do?
Posted Fri 12 Jun 09 @ 6:46 pm
Posted Sat 13 Jun 09 @ 6:06 am
