Forum: VirtualDJ Skins
Topic: Default Skin 6.0 to 1280 x 800 - Page: 1
hello
i have laptop with monitor 15.4, 1280 x 800
i using defaulit skin of version 6.0.1 widescreen.
this version is 1280x768.
can anyone modifed the browser skin to make 1280 x 800?
i want just resize browser from 768 to 800.
thanks
Posted Thu 11 Jun 09 @ 8:34 pm
When you maximize this skin, it occupies the entire screen. However, it does consume some CPU resources when maximized. Give it a try and see if it works for you without problems.
Hello,
If you know how the skins work (one XML file and one BMP file) it will be quite easy to extend the "browser" element.
If not, you can download the Skin Resizer Tool: http://www.virtualdj.com/download/trial.html
And use the "browser extend" option that is in the resizing options.
This will extend only the browser part without touching anything else.
i try with Skin Resizer Too but i can't do this..... :(
can anyone this resize of browser?
I already have a slightly modified version of the default skin. 1200x800
I was not going to upload it at this time but i could or send it to you aledjo.
just to clarify, does this 1200x800 skin have the 2 effect drop-downs?
id be intrested in it, too
same as default widescreen version, but i remade the scratchwaves, song times with bigger font and color changes, and of course 1200x800
Just little personal tweaks.
@listen2 can you send to me?
thanks
where download??
Hi, that looks great, can you put it up for general download if you don't mind?
Yes I will in a bit when I get home.
Sorry guys .. or anyone else waiting on this, I have been busy but i will upload this by the end of the day.
ok thanks!
beautiful, thanks!!!!!
thanksssssssss!!!!!!!!!
hi,
i want to replace icon played songs with another.
i try to edit .bpm file
i replace this icon but in vdj not work and show the default icon.
with other skin show the new icon when replace but in this skin not work.
can help me anyone?
thanks
in the browser section of the XML - you with need to add:
<custom icons x="xx" y="xx"/>
This will then use the icons in the bmp.
95%
