Before anyone says anything, I have exhaaaaauuuuusted the forums search resources, and have tried to resolve the problem with all previous post. Nothings worked.
I keep on getting the invalid skin file (error line 0 in the xml)
I haven't changed skins, haven't changed settings. Nothing. I was using vd this morning and it was running perfectly fine. I've tried rebooting, reinstaling. I got nothing.
PLEASE HELP!
PLEASE HELP!
Posted Thu 11 Jun 09 @ 6:46 pm
Can you get VDJ up and running. If so click on factory settings to see if this corrects the issue. Otherwise do a complete uninstall also I remeber that there is a tool available on site to clear the registry of any leftovers then reinstall.
Posted Thu 11 Jun 09 @ 7:40 pm
That's the thing....I can't. VD won't even open, start, or nothing. It's weird.
Posted Thu 11 Jun 09 @ 7:59 pm
Have you done a system restore before you installed before the issue.
Posted Thu 11 Jun 09 @ 8:02 pm
Which version are you using ?
Posted Thu 11 Jun 09 @ 9:36 pm
I'm getting the same message - Invalid skin file (error line 0 in the xml). Cant' someone help us, was working a few weeks ago but now nothing.
Posted Fri 19 Jun 09 @ 2:30 pm
I was having this issue when bringing my laptop out of standby mode, try rebooting your computer.
I stopped having this issue after I discovered this.
Posted Thu 25 Jun 09 @ 12:03 am
Check that your screen resolution size hasn't changed. This has happened to me and oce I corrected it VDJ opened.
Posted Thu 25 Jun 09 @ 12:32 am
