Greetings,
I could use some help please. I found an annoyance with video cue stuttering. I use cue-marks to jump between spots in the videos during my mash-up sets. Normally (Ver. 5.2.1) I'll jump back to say que-mark one, and the video will start playing immediatly with sound sync. I can hit que-mark 1 over and over, and stutter the video... which looks pretty cool.
Now I am finding that some vids at some que-marks have a delay in playing the video for one beat. Then after one beat it starts to have normal motion and is synced with the audio. This is a new occurance in V6.0.1. The last VDJ 5.2.1 had no issue like this.
I've tried options like hardware acceleration on/off and ratio settings, but no fix. I'm using a HP DV-9500 which up till now has had no problems other than the momentary freeze when loading a new video.
This is a dual core and I've also noticed some heavier CPU utilization. Does VDJ use the 2 cores? And any idea on what's up with this momentary video freeze?
Further experimentation is showing the video freezes for about 1 beat after the cue mark, I can roll back and forth the vid with my jog wheel and the video is static. If I rewind anywhere before the cue mark, it un-freezes the video and it will stutter normally, and have motion where before it was a static image. What the heck?
Re-setting the cue-mark no fix.
Problem clears only when I back cue to the point before the cue-mark... then the video starts motion again. Rolling forward to any part in the video past the other 2 cue marks and then back to the "no motion" area does not fix problem. Only when I roll back before the cue mark will it release the video to normal motion play. Very weird indeed.
Errrrrrrpppp.... more info. This has nothing to do with the cue marks. I can jump to anywhere during video playback and I will notice the video freeze. I can stop on the spot and go back and forth with the jog with no motion to the video. If I roll the vid backwards to when the video starts motion again, then the video will play normal with motion where it once was static video. Hmmmmm......
Thanks,
JimJam L HBGPA
Thanks,
JimJam L HBGPA
Posted Wed 10 Jun 09 @ 12:40 am
Couldnt have said it any better myself. I'm in the same boat, and unfortunately noone seems that noone can help us!
Posted Wed 24 Jun 09 @ 9:08 pm
vdj uses two cores
i had an isue with something named processor throtle for the intel 2 core procs
you need xp sp 3 and some reg edit
you'll find the info if you google it or look in the m-audio knowledge database
Posted Wed 24 Jun 09 @ 11:28 pm
