Hi guys, im trying to config VDJ6 with my denon 4500 controller but I cant seem to get the play button & cue button to do what I want......
I am after the play button playing when you press it if it is not playing and pause it if it is......easy i hear you say and yes i have managed to get it to do that :) but I am after it putting cue point 1 from where ever you have pressed play from last.....then i need the cue button to go back to that cue point, does that make sence? I think this is that way the boggis mapper does it if im not mistaken.
any help would be great.
Fatboy
Fatboy
Posted Fri 05 Jun 09 @ 5:21 am
Might be another way of doing this, but off the top of my head, for the play button:
play ? play_pause : play_pause & set_cue 1
I think this should perform play_pause, and if the action is to start playing, then it will set cue point 1 to where you are starting to play.
If you use this...
...it should do the same, but with the currently selected cue point, rather than cue point 1.
If you use this...
Posted Fri 05 Jun 09 @ 7:16 am
SB!!! you are a true gent!! thanks man, that works perfectly......just like the denon cd players :)
Cheers man!
Fatboy
Cheers man!
Fatboy
Posted Fri 05 Jun 09 @ 12:42 pm
No worries, I will mark the thread as solved :)
Posted Sat 06 Jun 09 @ 12:55 pm
