Hi all,
I'm considering upgrading from 5.2 to 6.0 soon-ish. I was just wondering if I was still able to use the same added effects that I used in VDJ 5.2 (such as the Cut effect). Will they be incompatible or should they still work?
Thanks
Thanks
Posted Thu 04 Jun 09 @ 10:46 am
All effects are compatible, except for previous custom controller DLLs (mappers).
Posted Thu 04 Jun 09 @ 11:09 am
I am trying to install the virtual vinyl and after i installed everything when i push play on my cd , it make a beeping sound can anyone help me so I can get this working
Posted Sun 21 Mar 10 @ 8:28 pm
Yes; I suspect someone can.
However it would be better to open a new thread rather than bumping an almost year old one that has nothing to do with the issue you have.
Posted Mon 22 Mar 10 @ 6:05 am
