i looking to buy a DJ set to go along with V-DJ cause it kind of hard, not really, to DJ with just the mouse. I did some research and i found the Numark CDX CD Turntable but they are expensive. I want to get those but is there other turntables out there that i can buy but cheaper?
Please help me out thanks :)
Posted Thu 04 Jun 09 @ 9:38 am
This all depends on what kind of djing you are planning on. If you are going for a timecoded setup, you can either run cdj's or turntables. A decent pair of stanton decks would work just fine for either vinyl or cd in my own opinion. If you don't scratch I would then reccomend that you go with Numark Total Control Controller (here is a link: http://www.numark.com/totalcontrol) with DjIo sound card, which I personally use for gigs along with my turntables for regular vinyl, or possibly go with the Hercules MK2 controller (here is a link: http://www.etcetera.co.uk/products/HER900.shtml) which works flawlessly with the setup and runs off of usb. The Hercules controller also has rca outputs on the back of the unit to allow you to run directly to a mixer and not have to run an external sound card. Hopefully this helps. God Bless.
Posted Thu 04 Jun 09 @ 12:42 pm
