All the files are at their folders, i mean dll's for sound effects, but in the VDJ there are only names of them, no active button or smth... WTF???
Posted Wed 03 Jun 09 @ 12:06 pm
I leveled up Patchyman's post.
LVL PRO
Posted Wed 03 Jun 09 @ 1:04 pm
Issue solved. Version 6.0.1 fixes the problem.
Thanks.
Thanks.
Posted Thu 04 Jun 09 @ 12:13 pm
in some of the what's new documentation for V6, there are tons of effects. I install 6.0 pro (upgrades from Cue 5.2 for $49.99) and all i see are the few I had with Cue 5.2.
Is the "what's new" screen shots of the effects include downloaded plug ins from the site? Any plugins tested with 6.0?
Posted Sat 06 Jun 09 @ 11:04 pm
Most/all sound effects work with v6 too
you can download here:
https://virtualdj.com/addons/effects.html
In addition, VDJ supports VST effects, and there are litterally thousands of them, ranging from free to costy
(VSTs are made by other companies, you'll find loads if you google)
Posted Sun 07 Jun 09 @ 12:25 am
need help..
where can i download effects 4 my VDJ 6.0...
Posted Sat 22 Aug 09 @ 9:40 am
Zero_Nine_Zero wrote :
need help..
For downloading skins, effects, mappers and other tools you must own a legal license of Virtual DJ.
Register your serial under 'Modify my profile' - then go to the download section and search effects for your version.
Greetings, Heiko
Posted Sat 22 Aug 09 @ 9:45 am
