Hi everyone,
I just downloaded the trial version and what i am trying to do is assign a key of my midi controller to adjust the cbg.
This was quite easy to do (adjust_cbg -2%) except for one detail. When I push the button the action is done but if i keep it pressed
the adjustment does not continue. I would like to avoid pressing and releasing the button each time. It would be nice
for the adjustment to continue as long as I keep the button pressed. Any ideas what command could be to achieve this?
thx in advance,
DeeP
thx in advance,
DeeP
Posted Wed 03 Jun 09 @ 10:02 am
Which midi controller are you using? It's possible it only sends the event once as this problem doesn't happen when using the same mapping on a keyboard.
Posted Wed 03 Jun 09 @ 11:04 am
It is a m-audio xponent...
Posted Wed 03 Jun 09 @ 11:50 am
