as i'm lookin to upgrade to this i have a question, i have two laptops, one a back up and i need to know do i have to buy this twice or can i install it on both from the one purchase?
Posted Tue 02 Jun 09 @ 12:25 pm
The EULA states you can install Virtual DJ on up to two PCs.
Posted Tue 02 Jun 09 @ 12:33 pm
You can install on 2 machine with one license.
EULA SUMMARY:
- This license gives you the right to install and use the software on a maximum of two computers, by one person.
- It does not give you the right to rent or sell computer systems on which the software is installed, or to rent or sell the software or part of it.
- The software is distributed "as-is" and no warranty of any kind is expressed.
- Atomix Productions and its suppliers retain all intellectual property rights in the software.
Hope to see you with us and you have a discount as you have the herc rmx;)
EULA SUMMARY:
Posted Tue 02 Jun 09 @ 12:34 pm
