I know this does not have much to do with VDJ but since we're all DJ's (and people tend to be nicer on this board rather than other places I've been) I figured I'd ask around here.
Basically, my problem is this: I can't seem to get my system in stereo.
I'm only hearing sound coming out of 1 channel.
The problem is how I'm forced to set this up. From the mixer we've got dual xlr's going into a single 1/4 input to the EQ.
Is there anyway I can get this running in stereo with this kind of setup?
Posted Sat 30 May 09 @ 12:06 pm
What kind of EQ (brand, model) are you using? If you dropping from a dual channel into a single there is your problem. Example: My EQs have left and right inputs.
Posted Sat 30 May 09 @ 1:00 pm
Well, it's not exactly an EQ - it's a bbe sonic maximizer. We use this instead of an EQ.
Since this thing only accepts single 1/4 inputs I'm wondering if there is any way I can possibly set this up in stereo.
Posted Sat 30 May 09 @ 5:52 pm
I use the BBE Sonic Maximizer 882i and a dbx DriveRack PX and don't have any issues. Have you made sure that inputs/outputs are not confused. Check the settings and cables on your mixer. What controller are you using? Maybe the soundcard settings are off. It could be any number of things.
DJ RuDeDoGG
Keep Spinnin' N' Grinnin'!!
DJ RuDeDoGG
Posted Sat 30 May 09 @ 8:02 pm
