Hey,
I have a DJIO that came with total control.
I use the total control for smaller shows. When i use the DJ IO without my total control (ill be using my ICDX)
should i power the DJIO using power and not just USB?
It didnt come with a power adapter, but the one that came with total control is the same voltage and it fits.
Is this reccomended? Or am i just wasting an extra plug?
Thanks.
Thanks.
Posted Sat 30 May 09 @ 9:49 am
I have always used a power supply with my DJIO. It means that the USB is then just used for data transfer rather than power too.
That said - i havent tried it without so it may not make any difference at all.
Posted Sat 30 May 09 @ 4:09 pm
i think it would depending on the enviroment to save power consumption.
when im using my ICDX' im using 3 of the 4 usb ports on my laptop
by using the power im not puttnig so much stress on the laptop for power
thanks for the answer.
Posted Sat 30 May 09 @ 5:56 pm
