Hi is it possible to use my setup with virtual dj? I've 2 cdj 1000mk3's, a djm600 mixer and an onboard 5.1 soundcard. Cheers.
Posted Tue 26 May 09 @ 6:21 am
As long as that 5.1 sound card has 4in / 4out and supports ASIO your good...
Should go something like this:
connect the CDJ's to the in on your sound card and run 4 cables out to the Line inputs on the mixer. Download the TCCD PRO files, burn as a Audio CD make sure NOT to normalize them. and then have fun.
Posted Tue 26 May 09 @ 8:16 am
Thanks, i figured it out. My onboard only had 1 line in but luckily i had a spare pci which i used.
I'm now also looking at getting a soundcard which could be used for a pc and laptop and came accross this - http://www.esi-audio.com/products/maya44usb/ - can anyone recommend it.
Posted Tue 26 May 09 @ 10:47 am
Yes I have it had have no issues with. Some other people on here have had trouble with it its all about price vs reliablity i think? there are a TON more out there but in the end its up to you.
good luck
good luck
Posted Tue 26 May 09 @ 12:14 pm
If you are using Club Standard equipment like that, Don't buy the ESI. There is a difference between ok, better and best. Get The Serato SL 1 Box or The M-audio Connectiv box, They sound cleaner & Work best. Spend your money once and not twice.
Posted Tue 26 May 09 @ 11:16 pm
Cheers for the advice. How would you recommend the m audio connective then? Traktor and serato both seem a bit too pricey for what I need it for, which is basically having my main collection on my laptop/pc.
Posted Sun 31 May 09 @ 2:09 pm
Notihing but positive and good things about the connectiv.... Its all about how much you want / can spend?
Posted Mon 01 Jun 09 @ 10:03 am
Guess I'll go for the connectiv then. Thanks for the help fellas.
Posted Wed 03 Jun 09 @ 8:22 am
Hello,
So here is what i have set up:
1) VDJ
2) PIONEERS CDJ 1000 MK3
3) DJM 600 MIXER
4) AUDIO 4 DJ
5) VDJ TIMECODE CDs
I have successfully connected everything, but i still have a problem. When i use the loop buttons on the cdj, nothing happens to vdj. Also when i change the pitch, it lags a lottt.. As for the cue button, its useless!!
I have seen videos of people controlling vdj with their mixer and cdjs. whatever button they press, it changes instantly on vdj.
So pleasee, how can i do this?? i have spent a lot of money on this setup, i do want to make it go to waste.
thank you
1) VDJ
3) DJM 600 MIXER
4) AUDIO 4 DJ
5) VDJ TIMECODE CDs
thank you
Posted Tue 14 Sep 10 @ 4:40 pm
