ok so ive just purchased some scratch live time coded vinyls.
but ive just found out the need the soundcard that comes with it which is like $500 and i seriously cant afford to fork out that much money.
and i got told that they work with virtual dj and i would be able to use my Hercules as a soundcard
will this work?
thanks
will this work?
thanks
Posted Sat 23 May 09 @ 7:21 pm
Hercules will work...
Posted Sun 24 May 09 @ 7:54 am
Yes it will work but you need to upgrade your software to Pro version as the DJC edition have limitations (example time usage etc) and also you cannot use external hardware!
You can upgrade to pro with a discount and i hope to see you with us soon;)
Posted Sun 24 May 09 @ 11:14 am
ok :)
yeah im still like £70 short :/
im currently working with some dj's to make a hardcore complation album which should make some money :)
anyone whos interested click the link below
http://www.djforums.com/forums/showthread.php?t=192400
Posted Sun 24 May 09 @ 12:08 pm
