I just bought a new macbook pro and I am having trouble installing the driver on the mac. The driver cd it came with did me no good and when I went to the website and downloaded the driver also did me no good. All it downloaded was like a notepad message with about bunch of crazy writing. Any suggestions?
Posted Tue 12 May 09 @ 9:47 am
its because you need this one
http://www.downloadsource.net/8530/Audiotrak-MAYA-44-USB-ASIO-Audio-Driver-MAC-OS-10x/
Posted Tue 12 May 09 @ 10:12 am
Cool! I will download and try it when I get home! Thanks for the help...
Posted Tue 12 May 09 @ 10:26 am
ok so its still not working. this is what comes up in text file
†Ï•≥[Hÿ|îºCòu>Ù≈ã∞Ø|„ÃìØ·„@∞ˇ’-Cl´PPâå=A
釢ÎAçÃ<äj˝ëÒá»yrâé∆YzÒ˛ SµrJRuÏÂt[π•∂*Ñ&2±®<&IÉe[-fı^r0=˚€í5 ÿûŒ…7;Qt&û )õ’ü\Òjõi…æ+N¸Oôõé°íî‘}-!4C”áI‚Ó£˚ä2áç'flÈÖƒÁ…©ä1Ìü≥Eé‚##âáò-ïèa>πå*’KÈù[3'p͸yù!c%V$∂= Õ>çf„õÖ óÊ∏•
a hole bunch of letters like this linking it to an
StuffIt (c)1997-2002 Aladdin Systems, Inc., http://www.aladdinsys.com/StuffIt/
I'm running a brand new Mac book Pro Mac OS X Version 10.5.7
HELP!!!!!!!!!
HELP!!!!!!!!!
Posted Wed 13 May 09 @ 10:57 pm
Is there a special application i'm supposed to have before Install Maya 44 USB Control Panel?
THe Cd does not work, the ESI website does not work, and the link to the website above does not work.
HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted Thu 14 May 09 @ 1:37 pm
you supos to download a sit file opener
http://my.smithmicro.com/mac/stuffitexpander/index.html hope this helps
Posted Thu 14 May 09 @ 11:38 pm
