Hi,
I have a macbook and a Zalman ZM-RSSC sound card. I have an issu while trying to configure vdj so I have a headphones output through the built-in and a master output through my card.
Even if the card I use is not supposed to go on macs, it works fine with everything. Even with vdj, when it's set on single output, the sound is good. However, as soon as I select the "2 cards" option, so i can use headphones, the sound off my zalman becomes disgusting. I have tried the same pattern on a pc, and it worked fine.
Do you think that my card is the problem or that vdj 5.2 for mac is the problem? any solutions?
P.S. Does anyone know how to change the value of a sample while configuring a midi device? It seems to be locked, however, on the windows version, it's not...
Thx
Thomas
Thx
Thomas
Posted Mon 11 May 09 @ 10:03 pm
