hello everyone.
its been a while that i'm working with VDJ, and after some trips through almost all genres of music, I finally settled down in techno. Well what I immediatly noticied is that Techno songs usually tend to be quite long. I must say that in my Techno library I've got hundreds of Tracks that easly get over 10 min. Well what I've then noticied is that VirtualDJ doesn't scan long tracks (I would say that if it is over 12 min it doesn't scan it). I really must say that this is for me an "pain in the ass".
I would really appreciate some help regarding this problem.
TY every1
TY every1
Posted Sun 10 May 09 @ 9:36 am
it seems that no one can reaaly help me until now..
here some extra details
I'm running vdj (DJconsole) 5.2.1 on windows xp sp2, and when i say it doesnt scan the song i mean it doesnt load it, it just loads the first 15 sec, and load the rest whil the song is playing
Posted Wed 13 May 09 @ 11:33 am
Juat a thought, have you looked at the Config/Options/Max Load setting? This governs how VDJ deals with long tracks.
Posted Wed 13 May 09 @ 2:14 pm
thank you for help , but i have problems reaching the config.... the only button i have says "more" and its for updating to vdj pro
Posted Thu 14 May 09 @ 6:42 am
Anyone know if the Config option is available on the LE version? I'm afraid I didn't spend enough time on that version.
Posted Thu 14 May 09 @ 11:28 am
I had the same problems! Sometimes I load 30 min pre-rpoduced mixes and it has a problem loading the song and sometimes cuts off the audio when it reaches the unloaded part of the song as well!
Posted Thu 14 May 09 @ 2:17 pm
isnt there any solution for my problem if i have limited edition?
Posted Fri 03 Jul 09 @ 10:25 am
The MAX Load option is pre-configured in the LE editions. That is why you can not 'fully' load a track. If you want the feature you need to purchase the Pro edition.
Posted Tue 07 Jul 09 @ 6:18 pm
