buford's got white out all over the screen , so i know he thinks he's fixing it .....
he can't figure out how to clear out some room in the recovery drive in order to defrag it ??
so how do you delete stuff outta yer recovery drive (XP home) ???
thanks fer any help , hope we don't have to call crazy Dave ......
Posted Mon 04 May 09 @ 9:49 am
Posted Mon 04 May 09 @ 10:06 am
The only way I know Chuck, is a complete re-formatting. Sorry....
Posted Mon 04 May 09 @ 11:39 am
when you say white out what happens on boot up and at what stage do you get 2 ? maybe able to help cheers Adrian
Posted Mon 04 May 09 @ 12:17 pm
uuuhhh thanks everybody ... the whiteout is how buford handles typos ..... yeah it's his own unique thing , anything on the screen that doesn't seem right , just white it out .......
but the D recovery drive with only 18% free space can use more free space ......
maybe i can delete recovery points ??
Posted Mon 04 May 09 @ 2:22 pm
The D drive will be a full manufacturer system restore which is independent to windows' system restore. Most laptops will come with software to make recovery dvds so that you can remove the partition to free space. If this wasn't an option but you feel you are computer competent and have access to a windows installation dvd and are happy to hunt for your own drivers then you may also remove the partition. By remove I mean either of two options, 1) you format the partition -or- 2) you resize your C so that it is larger overall.
If you want to delete recovery points, open your start menu and type in disk cleanup (if you're on xp it's under accessories and system tools). Under the more options tab there is an option to delete all but the most recent restore point.
However, if things are appearing on your screen which simply should not be there, it's unlikely defragging will fix your problems, at the worst, a badly fragmented drive will only slow your system down.
Posted Mon 04 May 09 @ 2:57 pm
thanks Andrew
can the disk mgmt softwares out there resize " on the fly" so to speak , without reformatting ??
Posted Mon 04 May 09 @ 9:36 pm
hi maty EASEUS PARTIONING MANAGER is a nice and easy partioning tool and best of all its free just google it that is a tool ive used and it is easy to use good luck
Posted Tue 05 May 09 @ 5:22 am
