Hi everyone.
Can anyone suggest a Rack mounting Kit for this mixer I would like to fit it in a 19\" Case along with my Hc4500
thanks
thanks
Posted Sun 03 May 09 @ 4:22 am
I did some random Googling and all I was able to find was this:
http://www.topdjgear.com/ecnu19raeafo.html
This rack kit is actually made for Ecler Nuo5, but both mixers have the same dimensions and I'm fairly sure they would fit. I doubt that Ecler would put the mounting holes to different places in each mixer...and even if they did, the worst case scenario is that you will have to drill few holes.
If you don't feel like paying 65$ for pieces of bent metal, rack rails are quite easy to make DIY if you have access to some metal working tools (or have a friend that has). All it requires is to do some measuring, cutting sheet metal to required dimensions, bending the pieces into L-shape, grinding the sharp edges, drilling the mounting holes, some black spray paint for finish and - VOILA, you're done :)
Posted Sun 03 May 09 @ 5:40 am
thanks for the reply. I wonder if they ship to the UK? & yes the price is high but i can live with that
Posted Sun 03 May 09 @ 6:02 am
