Hi looking for some help
I have ripped all of 2006 through 2008 Promo Only without a problem. I started ripping the newest discs first I am now on 2005
and I am having a problems with some of the discs ...the first track will rip and then it stops and I get this error
" Please selects VTS/ PGC / Chapter(s) / cells to be copied / decrypted "
any suggestions on how to fix this I am confusd because all of the other years/ discs ripped . Is the dvd set up different in 05
Thanks
Ed
Thanks
Ed
Posted Fri 01 May 09 @ 6:07 am
it's just a CD that. He is broken.
Posted Sat 02 May 09 @ 7:00 am
I am not sure what youa re trying to say ... it does play in a dvd player and I can rip it in DVD Decrypter without using the Dj Extractor program
Anyone have this problem ????
Thanks
Ed
Thanks
Ed
Posted Sat 02 May 09 @ 9:17 am
Anyone have this problem ...any suggestions on what it could be
Posted Mon 04 May 09 @ 4:47 pm
Try Smartripper. I have every PO DVD since they came out and have had no issues ripping with smartripper. Do a search here for the settings. You will have to manually type in the info, but u will be able to rip the dvd.
Posted Tue 05 May 09 @ 2:58 am
Brian
I was trying to avoid typing but I may have too any setting recommendations
Thanks
Ed
Thanks
Ed
Posted Tue 05 May 09 @ 7:54 pm
