Howdy folks,
I have been using VDJ for a while, on my laptop with a basic sound card, with no PFL :(
I've put together a few mixes - mainly by setting cue points on the tracks to ensure I mix in/out at the correct time.
However, I would really like to get a decent usb sound card and/or usb mixer to allow me to split channels and control VDJ externally via the mixer.
All of my music is digital, so all I need to do is pre fade listen with the headphones and control EQ's, fades etc with an external mixer.
Does anyone have any ideas or possible solutions?
I have produced some reasonable mixes, but need more kit to take it to the next level....
Check out the progress so far:
http://www.house-mixes.com/artists/Clive_Thornton/
http://www.divshare.com/download/6996967-94f
http://www.divshare.com/download/7236349-1fc
Thanks
CMCD
Thanks
CMCD
Posted Thu 30 Apr 09 @ 12:28 pm
Sounds like a simple solution! either RMX or VCI300
Posted Thu 30 Apr 09 @ 12:56 pm
