Hi
I want to buy a controller. ATM i only have a macbook pro:) I want to mix avis and qtime movies.
I was looking into numark total control but it does not have a headphone jack. Can this be solved with the numark DJIO?
The Hercules DJ Console RMX/The Hercules DJ Console Steel looks very professional, not like a toy, does it work with vurtual dj?
Thanks any advice would b much appreciated
R
R
Posted Mon 27 Apr 09 @ 9:53 am
The RMX and Steel controllers from Hercules come bundled with a Limited Edition version of Virtual DJ. These come out of the box ready to go with the VDJ software included.
I have the older Hercules controller, MK2, it works great with VDJ and from what I've heard and read the RMX is an improvment on the older controller.
There are many other controllers available, research. An educated purchase makes you feel good.
Posted Mon 27 Apr 09 @ 9:57 am
Thanks for the reply. yes i need to do some more research but i want it now ! :) gonna look around some more.
R
R
Posted Mon 27 Apr 09 @ 10:27 am
The RMX Works with Vritual DJ. I would suggest you stay away from the RMX steel. For the reason you might have to pay for an extra sound card. You will be very satisfied with the Hercules RMX. You can map it out how every you want to use it with Vritual DJ 6.0.1 You can't go wrong with this investment. I'm And exclusive Hercules RMX DJ user, and have not every had any issues since I purchased it, not even a crash. I still carry a Numark CD mix2 just in case. You alway should have a back up with any system. LOL
Posted Tue 14 Jul 09 @ 5:10 pm
if you are interested i'm thinking on selling my total control with the djio included. this controller is a plug and play. had no problems at all.
it just work perfect with virtual dj.
Posted Tue 14 Jul 09 @ 5:15 pm
Hey...
I wanna get a new controler that suitable for VDJ Pro 6...
My options are either Allen & Heath Xone:2D or Denon DNS 1200...
I know Denon is suitable for VDJ 6, but how about Xone:2D?
Because i'm more interested with Xone:2D than DNS 1200...
and i wanna get external mixer that suitable with internal mixer that VDJ 6 has it...
My budegt is only $500 for mixer...
I know some Numark external mixers are suitable with VDJ 6...but too bad they dont have built in effects...
But I'm more interested with mixer that has built in effects...and MIDI integrated...of course, my budget is only $500 for it!
How bout Vestax PMC-280?
But i dont like Bheringer products (even DDM 4000)...
Or do u have any option for me?
Please help me...
Thank you!
Please help me...
Thank you!
Posted Tue 14 Jul 09 @ 6:42 pm
I've had the opportunity to compare the MK2 with the RMX because I have both. The MK2 isn't a bad little all-in-one controller, but the RMX puts it to shame in many ways: space, feel, construction, jogwheel resolution, pro outputs, etc. The RMX is a solid all-in-one for the DJ on a tight budget (like me, lol).
Posted Tue 14 Jul 09 @ 10:26 pm
