reinstalling vdj 5.2.1 pro on to a new laptop with vista ihave the hercules console mk2
i installed the DJConsole virtualdj_djc_v3.4.1.exe (50 MB) driver plugged i the herc as asked then it said it could not find the drivers asked for the cd but it couldnt see the driver on the orig cd either
what do i do here ?
what do i do here ?
Posted Sat 25 Apr 09 @ 6:03 am
its now asking for the asio driver??/ what are they and where do i get them?
a bit lost with this
Posted Sat 25 Apr 09 @ 6:04 am
It sounds like the drivers are not fully installed.
Have you tried installing the latest Hercules driver package (Apr 09)
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=1
Posted Sat 25 Apr 09 @ 6:44 am
yes installed that first if that the 3.4.1. . ive now got it all installed but the console herc mk 2 does not work. i get sound through the amp ok but i have to operaate all the cues etc from the vdj laptop interface, nothing on the console works
The green lights are lit on the Audio sourse button on the console
i have the dj console icon running in the taskbar and can open it
Posted Sat 25 Apr 09 @ 12:58 pm
No that link is for the latest drivers, not the 3.4.1 version.
Anyway could you try this then try,
In the mk2 control panel, set to WDM mode.
In VirtualDJ>Config>Sound Setup tab set
Input - None
Output - Headphones
Soundcard - MK2 Icon
Uncheck, Apply Eq to External source (or something like that)
Give that a go and see if you can control things. I've got to go out now to my gig, but if you have anymore problems I'll have a look in the morning,
Posted Sat 25 Apr 09 @ 1:46 pm
yep cracked it thanks for your help and support
Posted Sat 25 Apr 09 @ 1:58 pm
