Hey all
I was wondering if you could help me. I went to run virtual dj last night, I have had to do a few re-installs of it, so cant remember what the settings were but never heard this before.
The challenge is when i am going to record i am getting weird noises from the hercules whenever i turn any sort of nob(volume/bass/mid/gain)you can hear it making a noise even on the recording. I am running it in WDM mode but cant seem to get it to run in ASIO mode cos of the latency.
Can anyone help please?
Thanks
Sean
Thanks
Sean
Posted Tue 21 Apr 09 @ 2:01 am
Try this:
- At VDJ performance tab, set latency to AUTO
(this should fix it)
Additionally try this, if on laptop:
- At VDJ performance tab, try Overclock ON, and OFF, see what works best on your pc
Last resort, if your pc cant handle the audio well (due to irq conflict etc)
- At VDJ performance tab, try Safemode ON
Posted Tue 21 Apr 09 @ 4:27 am
hey mate
thanks for this, the last one worked all the others didnt. Didnt have this problem before i had to do a re-install so thats weird. Whats an irq conflict?
Posted Wed 22 Apr 09 @ 6:22 am
