Xponent doesn't work with VDJ Anymore. (AGAIN)
Am having issues with the Xponent Controler in VDJ. Every time i try to use it today and yesterday it doesn't work anymore. I am able to load the Xponent in Config/Remote, it's greeen and all, but nothing is happening when i use the Xponent. I know this much, if i use General Midi and assign some key's it works great, so i know that it reconize my xponent and it's not broken.
I had this issue before once, i had to reformat all 3 of my computers to get it working again. Wiche doesn't Make any sense, as at least one of those computer never go on internet or anything, one day it works the other it doesnt, with no change at all whats so ever.
I have latest drivers, it work's in Torq and everything. Is there a Hard Reset or something we can do on the Xponent or VDJ Side ??
Anybody knows a fix or a work around ?
Thanks in advance
Cid K
Thanks in advance
Cid K
Posted Fri 17 Apr 09 @ 4:23 pm
If your using a mapper then maybe try deleting and reinstalling it.
Or maybe re-installing VDJ as something may have become corrupt or gone missing within the file system.
Posted Fri 17 Apr 09 @ 4:54 pm
Tried all that already, am using the built in Xponent mapper.
I guess ill have to reformat all my computers again...
Posted Fri 17 Apr 09 @ 8:30 pm
UPDATE:
I just finished formatting my Macbook Pro Laptop, installed VDJ 5.2.1 Pro, my Xponent drivers and Torq 1.5.1.
Torq works like a charm with Xponent, but VDJ still nothing... That kinda sucks ball's
Anybody has suggestions ?
I remember the last time it worked, the Xponent crashed on me while mixing at home, ive closed down everything and stored it for the day. Maybe the controler is looked on something or what not.. i dont know. Is there a way to Hard Reboot it or something ?
Posted Fri 17 Apr 09 @ 11:46 pm
UPDATE:
Torq works like a charm with Xponent, but VDJ still nothing... I am able to custom map everything by hand in that GENRAL MIDI Tab and once they are set it works, but if i choose the Xponent, it doesnt, no respons on it at all. That kinda sucks ball's!
I remember the last time it worked, the Xponent crashed on me while mixing at home, ive closed down everything and stored it for the day. Maybe the controler is looked on something or what not.. i dont know. Is there a way to Hard Reboot it or something ? Since i know the controler works fine.
Posted Sat 18 Apr 09 @ 1:25 am
Stupid question, what is the bank switch set to on the front?
Posted Sat 18 Apr 09 @ 4:02 am
MMMMM Prettty good question... but... where's is that Bank thingy ??
Posted Sun 19 Apr 09 @ 1:20 am
DAMN Found it, it was that Bank Switch, it was set on B... I have no clue why i didnt try that before, honestly it's the first time ive noticed that switch.
Thanks it's working great now. :-D
Posted Sun 19 Apr 09 @ 3:05 am
Glad to hear it. I'll put in a suggestion that both banks are supported the same :)
Posted Sun 19 Apr 09 @ 5:30 am
Or at least write it somewhere that when it's on B switch it doesnt work. Am pretty sure more cases like that will happend.
Thanks again for the help SB
Peace
CidK
Peace
CidK
Posted Mon 20 Apr 09 @ 2:11 am
