I decided to finally give this a try. Got everything set:
My 2500 has latest versions of firmware and I have the Asio Drivers installed
VDJ Pro installed
Had everything properly hooked up and had the VDJ sound playing through my 2500 and mixer, but no actual midi control of the software. In the remote control options in VDJ, the 2500 option is present but shows red when selected/activated, not green as it should. Any suggestion? Thanks in advance for any help.
VDJ Pro installed
Posted Fri 17 Apr 09 @ 7:26 am
