i just bought the ion usb turntable (ION TTUSB10)
i wanna kno if i can use it with virtual dj ( only using the usb cable)??
Posted Tue 14 Apr 09 @ 7:25 pm
Usually USB turntables are not designed for the type of activity you want to use it for. My personal experience with USB turntables is they were designed for transferring vinyl to MP3 format, and not much else. Without knowing the specs for the particular turntable your asking about my answer is no.
Posted Tue 14 Apr 09 @ 8:55 pm
the ion is only made for recording onto pc, though vdj may be abel to pick up a signal off of it
crappy moter and belt driven not a wise choice for dj'ing
Posted Wed 15 Apr 09 @ 12:55 am
i have this tt
youre probably not going to be able to do any scratching man
the cool thing about this tt is that it comes with a free version of audacity
you can use this software in partial conjunction with vdj to make some pretty cool tracks
audacity allows you to record layer after layer--------like having a 24 track studio!
Posted Wed 15 Apr 09 @ 3:25 pm
just bought one today and am going to look into virtual vinyl , i also use a total control but im gonna take a 2 channel mixer and have my laptop run to 1 channel and see if i can connect the audio outs from the ion usb table to chaneel 2 and see what happens with that
Posted Sun 03 May 09 @ 3:36 pm
The audio signal from the included cartridge might be out of spec for the VV souncard to detect. I ended up using a set of m44-7 shure carts for reliable signal.
Posted Sun 03 May 09 @ 9:26 pm
