I'm running a Macbook unibody with vdj pro 5.2 with a Hercules RMX. That said, I'm trying to setup timecodes and I know that you have to tweak the ASIO settings on the RMX Control Panel. The problem is my Control Panel looks like the one in the picture but it has no ASIO tab or chooser for "WDM" or "ASIO" at the bottom, they're just not there. I've tried redownloading the driver and still nothing.
Posted Sun 12 Apr 09 @ 4:42 am
ASIO doesnt exist on Apple Mac OS. It's only a protocole on Microsoft Windows.
WDM = Windows Driver Model so only for MS Windows ;-)
http://en.wikipedia.org/wiki/Windows_Driver_Model
(PS:
On Windows, you will find drivers as .SYS file
Found in the C:\Windows\System32\drivers folder
On Mac OS, you can find some drivers as .KEXT file:
Extension file used by a specific program or hardware device; often a device driver used by peripheral devices; primarily found in the /System/Library/Extensions folder.)
(PS:
Posted Mon 13 Apr 09 @ 5:21 am
thanks for your help
Posted Wed 15 Apr 09 @ 1:40 pm
