What would be a good size for mobile DJ work, 22", 32" or 42"?
I currently use a projector but sometimes space is limited.
Posted Thu 09 Apr 09 @ 12:48 pm
work it on the assumption what you can comfortably lift by yourself... 17" monitors would do me fine at the end of the night... lol
Posted Thu 09 Apr 09 @ 3:47 pm
I currently use a 37", not to heavy, not so small it's just right for me.
Check my pics....
Check my pics....
Posted Thu 09 Apr 09 @ 4:26 pm
I like your setup. What tripod stand are you using for the LCD and how did you mount it. I need details. I want to get the same
Posted Thu 09 Apr 09 @ 6:57 pm
I got the idea from Kamakuakane check it out here,
https://virtualdj.com/homepage/kamakuakane/blogs/1507/Equipment_Rack_Photos_(Top_Half).html
Posted Thu 09 Apr 09 @ 7:18 pm
I use a 42" Samsung. It's less than 50 lbs. With the mount that I created, it is very easy and quick to mount to my lightstand. Might upgrade to a 50" if I can find one at the right price. They way about 85-90 lbs, which is still within the weight limit of the lightstand.
Posted Thu 09 Apr 09 @ 9:57 pm
Nice setup djpr1... you obviously have alot of $ to blow!
Posted Thu 09 Apr 09 @ 11:43 pm
Just did this with a 32 Vizio, had a pole mount made locally, works perfect on a speaker stand.
Posted Fri 10 Apr 09 @ 6:50 am
Thanks bro, don't know about the a lot of $ part, but i have a lot of credit cards tho...LOL
Posted Fri 10 Apr 09 @ 9:09 am
