How many Mac users out there using bootcamp to run VDJ? Just got my new macbook pro and everything works great except for the fact that im having trouble with my external HD. Thinking about running windows via bootcamp. Anyone out there doing this and how do does it work for you? Thanks.
Posted Tue 07 Apr 09 @ 8:38 pm
what problems are you having? the only problem i really have is that the tracks load slower from my hd
Posted Wed 08 Apr 09 @ 1:37 am
I just started running VDJ in windows via bootcamp. I haven't had any issues as of yet!!! knock on wood, I also haven't gigged with it yet. I also do not run an external HD on the windows side. I run all my music from the internal hd.
Posted Wed 08 Apr 09 @ 9:29 am
my macbook pro reads the external hard drive but it wont read the database so all of my music video titles that i had to manually enter after i decrypted the discs are gone. I wouldnt really care too much but if i cant reformat the hd im going to have to rename all 800 videos i have.
Posted Wed 08 Apr 09 @ 5:01 pm
Instead of bootcamp try using Parallels 4.0 or VMware for your windows install on a Mac. Works better and no need to reboot when switching environments.
Posted Wed 08 Apr 09 @ 8:55 pm
Whilst what you are saying is correct i wouldn't run a gig through a virtual pc.
The main reason being is you are running TWO operating systems at the same time and needing more system resources to do so. Then add Virtual DJ into the mix and you are seriously putting some unneeded pressure on the system.
If you can't use the Mac version of VDJ then use Bootcamp (IMO) is the only sensible option. =)
Posted Wed 08 Apr 09 @ 9:05 pm
Use bootcamp. Parallels or VMware do not work better thank boot camp.
Posted Thu 09 Apr 09 @ 3:36 pm
