Id like to find information on how to setup the Audio8 Dj box with VDJ in OSx.
I tried with what i already know, Aggregate device and all, and it's not working for me. NO sound what's so ever.
I have a Macbook Pro (Unibody) 15", 2.4 ghz and 2gb of RAM.
Thanks and Cheers
Thanks and Cheers
Posted Mon 06 Apr 09 @ 2:58 pm
The Audio 8 DJ needs a driver installed on OSX which u can get from the NI website
Posted Sat 11 Apr 09 @ 3:34 pm
Yeah i got that, i even tried to setup he aggregate device, but i cant get sound or anything ...
Posted Sat 11 Apr 09 @ 4:11 pm
I have to say I just installed and it worked sorry I can't help more
Posted Sat 11 Apr 09 @ 4:13 pm
Really, what type Mac do you have ? You didnt need to setup an aggregate device ??
Posted Sat 11 Apr 09 @ 4:15 pm
I use the new unibody mac book pro that i that i got last nov
no aggregate device just select it from the drop down in VDJ
Posted Mon 13 Apr 09 @ 2:01 pm
Nice... Wiche driver do you have for the Audio8 DJ ??
Posted Mon 13 Apr 09 @ 2:20 pm
This has now been resolved off line :)
Posted Thu 16 Apr 09 @ 5:35 am
Hi.
My program crashes whenever I try to setup run the timecoded function using the Audio 8. Please advise I am using a Macbook and a VDJ Version 5.2.1 Mac.
Regards
Icy Cool
Regards
Icy Cool
Posted Mon 20 Apr 09 @ 6:33 pm
I dont use timeocodes sorry but i cant help
Posted Wed 22 Apr 09 @ 1:56 pm
I also run into problems when attempting to connect audio8 with VDJ and use my Pioneer CDJ1000 with timecode. Does this mean that VDJ does not recognize the audio8 and timecode? If so, does that mean that a high quality soundcard like the audio8 does not work with VDJ? I am confused when attempting to search for a definitive answer for this. Please advise
Posted Fri 15 May 09 @ 8:03 am
i want to us VDJ on audio8 help me plase
Posted Thu 04 Jun 09 @ 5:49 am
This Will Help A Little......
http://www.facebook.com/album.php?aid=104264&id=1346757089&l=ec14810859
Thanks.
Thanks.
Posted Fri 31 Dec 10 @ 9:15 pm
Confirmed! :) Audio 8 DJ can now be used for timecode with VDJ 7.0.2 with just a little but... :(
I can't view timecode configurations. I tried so many times but everytime I click on the "timecode config" button or the "apply" button after setting the inputs and outputs on the advance configuration panel, VDJ freezes. So I have to click "OK" directly.
Is my Audio 8 DJ pre-configured behind the scene?
Specs: Mac OS 10.6.4
Posted Mon 03 Jan 11 @ 4:10 am
Hi
My Feeling Is The Trouble With Your Software.But I Cant Help Much Further About It Because Im PC.
Try It Again By Clicking The "Restore To Factory Settings" In The Info Tab.And Also Cable The Audio 8 Dj Again.Take The Help From This Video.Maybe U Already Now.
http://www.youtube.com/watch?v=Tr6lFLMDE7E
Also Contact "Mark Settle" In FaceBook.Surely He Will Help You Until You Success.
Thanks
Best Regards
Dj Chamath
Thanks
Best Regards
Dj Chamath
Posted Mon 03 Jan 11 @ 6:40 am
Hmm, i work sometimes with TCCD and the Audio8DJ.
Since the V7 it works pretty good with Timecode.
Can you tell me something about your setups and your adjustments?
BTW:
BTW:
jpboggis wrote :
You will need an Intel Mac with MacOS 10.5 or later installed.
PowerPC and MacOS Tiger are no-longer supported.
Posted Mon 03 Jan 11 @ 9:13 am
