I need to optimize (tweak) my settings. The default external control settingswith CDJ1000's are horrible. Please see my linked pics:
http://powermixx.com/a_temp_dir/virtualdj/
What tweaks can I do to get the best performance when using external control with CDJ1000's? When I cue up and stutter on the CDJ, it slips, even slides off the cue point. Help!
Posted Fri 03 Apr 09 @ 8:41 pm
Well I don't know about your slipping cue points but after looking at the "timecode detailed" pic I see that you have perfect circles but the gain is way too low. Clicking "auto-config" should fix this so you get a stronger incoming signal (and much bigger circles). Or you can just increase the gain slider until the circles are nice and big and fill the box.
Posted Fri 03 Apr 09 @ 10:14 pm
