Hi ppl !
i,m using a shuttle pc with a 1.5 amd processor and 2gb ram ,and a creative audio audigy pci soundcard but i can play some mp3,s but it won,t play or show some other mp3,s and wav files and the graph doesn,t appear at the top of the screen as if there has been no track placed on the deck ??
when i do try to play them they will play for 2 secs then glitch off and after say another 4 secs they come on playing but then go off again ?
i,ve installed all the codecs and even tried converting the mp3 track into a lame mp3 but i still have the same problem and sometimes it will even crash if i try to play on both decks , but i,ve found out since if i just click on the track and then preview it instead it plays perfect but as soon as i drag it onto the deck again theres no sound or graph showing at all ??
can anybody put me out of my misery ?? !
Posted Tue 31 Mar 09 @ 3:09 pm
