I just purchased a Vestax VCI300 and out the box works great with itch, but I am having touble getting the sound setup right. Currently I have it configured :
inputs - none
outputs - single output
souncard - simple
souncards - vci 300
Any suggestions on how to rememdy this or is anyone else having the same trouble.
Thanks in advance
Dave
inputs - none
souncard - simple
souncards - vci 300
Thanks in advance
Dave
Posted Sat 28 Mar 09 @ 12:49 pm
You could try this
Inputs: None
Outputs: Headphones
Soundcard: VCI300
See it that works
Posted Sat 28 Mar 09 @ 12:56 pm
Thanks Jimmy B , pretty much tried every configuration and no luck. I'm prolly overlooking something simple. I was hoping someone had the same problem or a VDJ developer could help out.
Thanks Again in advance
Dave
Dave
Posted Sat 28 Mar 09 @ 1:03 pm
what is your operating system???
my set up
none
single
simple
vci-300 out idle
my set up
none
single
simple
vci-300 out idle
Posted Sat 28 Mar 09 @ 3:04 pm
Vista 32 bit duo core 2ghz with 4gb ram
Posted Sat 28 Mar 09 @ 3:29 pm
what is out idle
Posted Sat 28 Mar 09 @ 3:30 pm
Hey Sirkitbreaker my VCI soundcard choice is speakers (2- VCI 300) does this mean anything?
Posted Sat 28 Mar 09 @ 3:34 pm
