I have a netbook that I wish to experiment using with VDJ. None of the skins are the right aspect/resolution. It would be nice if VDJ were scalable, but until then, I am subject to those whom are smarter and kinder than I. Most of the netbooks I have seen max out at 1024x600. It should be usefull for others as well. I'll take anything anyone is willing to produce, but am a fan of the JN-Black designs. I doubt netbooks will handle video...
Many thanks in advance!
Stephen
housemusicvineyard@yahoo.com
Stephen
Posted Sun 22 Mar 09 @ 9:39 am
The testing I have done so far indicate that netbooks are probably a viable option to run VDJ. I have a borrowed Acer Aspire One that costs about $300. The netbook has to be returned soon and since my laptop still works fine...
The only issue other than normal laptop (soundcard/controller) issues is the screen resolution and aspect ratio. The resolution needs to be 1024x600. If it is not, part of the screen is unavailable.
Posted Tue 24 Mar 09 @ 7:35 am
You can use JeremK's Skin Resizer to turn a skin into 1024x600
https://virtualdj.com/addons/7187/Skin_Resizer_Tool.html
I do not think there are any skins with that exact aspect ratio, but 1280x800 is fairly close if you want to have a go at resizing those.
Posted Tue 24 Mar 09 @ 8:05 am
Here it is:
https://virtualdj.com/addons/4506/
Posted Tue 24 Mar 09 @ 8:20 am
