Im looking to stream live mixes to Live365 but using the mic also for talk. The Hercules only has 4 inputs so if i want to use the mic also I have to wait until i am using inputs 3+4 , switch the Mk2 control panel to MIC rather than Line, then start talking. All a bit of mess. Does anyone know
1- Is there any way of the Hercules taking in the mic input PLUS my decks for Virtual Vinyl?
2- Is there any way of using the soundcard on my Mac and the line in/internal microphone?
3- Are there any controllers on the market that you can use TCV and a Mic at the same time?
As I am broadcasting I want to ensure the ID3 tags of the tunes show up when I stream so I am having to use the mixer capabilities of the Hercules MK2 rathe than my Pioneer DJM600. Waste of my Pioneer but I cant see any other options
Posted Sun 22 Mar 09 @ 8:03 am
Virtual Vinyl is intended for use with a MIXER.
A hercules controler is designed as a all in one unit for standard use and moderate scratching.
The VV box is aimed at turntablists.
Perhaps you could use this setup.
TTS > VV > MIXER > Line IN/Mic.
Posted Sun 22 Mar 09 @ 10:54 am
Can you explain what your abreviations mean please.
Posted Sun 22 Mar 09 @ 1:24 pm
