Hi i am looking into getting a numark omni or stealth controller.
Just want to know if there is any difference between these 2 as they are about the same price and just want to know which 1 will work better with virtual dj also does any1 know if these are any good.
Rob
Rob
Posted Sun 22 Mar 09 @ 6:27 am
They will both work with VDJ via our handy mapping template in the next update a preset will be added for both.
The difference is the omni includes a soundcard and the steath is for people who aready have a sound card and dont need one.
Posted Sun 22 Mar 09 @ 6:50 am
Rob
I bought the sealth controller and i have the Virtual dl 5.2. Can you tell me how to activate it ???? Thanks!
Rob
Posted Thu 14 May 09 @ 12:58 pm
Hi you need a mapper to activate it as its not got full native support from virtual dj.
I brought the omni and did not like it at all so have gone back to a total control as i find these much better.
Posted Fri 15 May 09 @ 5:43 am
Oh and as i see you have no virtual dj license which meens you are on a trial version or you have a pirate version.
This meens you wont be able to download the mapper until you buy virtual dj
Posted Fri 15 May 09 @ 5:46 am
