Hey guys
A friend of mine recently purchased the numark stealthcontrol and ran it with VDJ. After downloading the midi mapper to configure it, it worked fine except that it wouldnt light up. Im thinking of getting the hercules rmx really soon, but my only worry is that there will be similar lighting issues since it is not officially supported on the 5.2 release (i.e i dont see it listed as one of the controllers under the 'remote control' tab in settings). Could anyone shed any light on this pls? (pun intended) ha ha. thnx.
Posted Sun 22 Mar 09 @ 3:09 am
it's linked with the mk2 controller i think, not all lights on the rmx illuminate as hercules designed it that way, as it draws its power from a usb port and not from a psu.
Posted Sun 22 Mar 09 @ 3:50 am
As Tayla said, the use and activate the RMX in VirtualDJ you must use the MK2 Icon, for some reason the Dev team has never put a RMX icon in,
Also to repeat my mate, only 16 buttons on the RMX have the blue backlighting, this was something Hercules "seemed" to forget to tell everyone when the were promoting the RMX.
Posted Sun 22 Mar 09 @ 4:07 am
to be honest i don't think i would have bought if i had known, but now i have getting used to being depraved deprived... lol
Posted Sun 22 Mar 09 @ 4:19 am
